noobster
Old 12-07-2010 | 01:09 AM
Default noobster
hey, i am thinking of buying a 27 ft from the late 70s with no motor.
it is set up for a chevy 454, Question
whats the difference in a long block chevy 454 for the street and a marine 454?
i know the cam is different, are the valves and heads differenet tooo but im guessing the blocks are the same correct?
CsChuck14 is offline
Old 12-07-2010 | 01:06 PM
Piston to wall clearance should be set up looser
Cam difference.
Brass feeze plugs.
Spark protected ignition, starter, alternator.
Marine carb with J tubes.
Those are the main differences.
Griff is offline
Old 12-07-2010 | 02:45 PM
ok, and what if i were to swap a gm diesel motor, the 6.5L basic gm motor? or a cummins? should i just buy a ready to go marine diesel? or would a street version do the same job?
Old 12-07-2010 | 02:50 PM
i would have to get a new transmission for a diesel?
Old 12-07-2010 | 06:43 PM
A pick up diessel is different from a true marine diesel. Way different. I wouldn t even try that. totally different animal.
Allicat38 is offline
Old 12-07-2010 | 09:36 PM
if you ran a seperate closed cooling system, you might be able
to get away w/ the truck diesel-but I wouldn't bother unless
you were gonna go with a duramax! and that would cost ya
some coin!
blownjet 468 is offline
