Need and Engine Expert
I have two questions:
1.) How many water drain plugs are on a 454 Bowtie block casting #10051107? I can only see one on the starter side but want to be sure for winterizing 2.) Approx how much antifreeze does the block itself hold if pouring in from the intake manifold? I would appreciate your help |
Originally Posted by superboat1982
(Post 3271891)
You can't really just drain and pour in anti freeze. What kind of drives are you running? I would recommend pulling the thermo stats and running the boat on a hose that is drawing from a bucket full of antifreeze. It will probably take 4.5 gallons, but buy the extra gallon - cheap insurance.
Originally Posted by wjb21ndtown
(Post 3271904)
Or just hook up antifreeze up to the water intake, run the boat till you get antifreeze out the exhaust and you are done..no need to drain anything...fog thru carb with ATF after you get anti thru...Rob
Originally Posted by ezstriper
(Post 3272031)
Depending on where you boat, its a good idea to drain the block to get sand/dirt out of the block. Buy a gallon of antifreeze mix it 50/50 and pour it down the intake manifold. |
Ok, this has been covered so many times. This is how I do it.
Flush the engine with fresh water and warm up the engine. Drain the water. Get a hose and suck the RV antifreize out of a bucket into the engine until it comes out of the tips. |
Originally Posted by jeffswav
(Post 3272092)
Originally Posted by Flyin-Bryan
(Post 3272022)
So if I pull the block drains,drain out all the water,I pour in antifreeze in through the big hose in the circ pump until I start to see if run out of the block drains,install the block drains and keep adding until it overflows out of the thermostat housing,this does not take care of the block for the winter?
You can do it this way, but IMO you're not covering everything properly. I prefer running antifreeze through the drives, seawater pump, etc., you can rely on gravity to get it out if you'd like, but I prefer forcing antifreeze through everything. Plus, it's more difficult to pump the antifreeze through the circ pump than it is to muff the drives with ears, or rig something so the seawater pump sucks the antifreeze for you. |
(Post 3272273)
| All times are GMT -5. The time now is 05:52 AM. |
