cigarette topgun drive hight >
Old 12-12-2010 | 01:45 PM
Default cigarette topgun drive hight
Looking to purchase imco shorties for my 1994 38 topgun ( 525-550 HP with Bravo one ) and wondering about -1" , -2" or standard drive height. anyone with experience with this setup. Also looking for low water pickup used on topguns with TRS setup.
Rudd Jr is offline
Old 12-13-2010 | 08:05 AM
LAKESIDE RESTORATIONS's Avatar
Lakeside Restorations.com
I am a dealer of theirs & offer their products..
Usually most people do the -2" unit. Reason being if you are trying to go as high as you can for the most speed and least drag you can start here. Then if you need to drop the unit down a little you can add spacers in as little 1/2" increments without having to buy another lower.
The 3" shorter unit and 1' shorter unit are not as commonly used, and the 3" unit wont fit all prop diameters.. Hope this helps you.. Jamie / Lakeside
www.LakesideRestorations.com 570-639-2628
We Make Fast Toys Faster, Cool Toys Cooler and Old Toys New!.. Performance, Custom & OEM Parts & much MORE![/CENTER]
LAKESIDE RESTORATIONS is offline
Old 12-14-2010 | 05:04 AM
Biggus's Avatar
From my experience, the straight bottom Cigarettes do not respond well to excessive propshaft heights. I've done quite a bit of testing and found that 3.5" below the bottom was as high as you could go before the slip went out of control (25%+) and that was with a SSM gimbal that put the drive further back and a 5 blade Hering. For a Bravo application, I think most would agree that 4.5"-5.5" below works the best.
Kurt
Biggus is offline
Old 12-14-2010 | 08:16 AM
great info, thanks
Rudd Jr is offline
