AN hose sizes for cooling.
2 Quick questions for the masses:
1) What size (-AN) do people normally run for hoses from T-stat to the Exhaust (CMI) distribution tube. and 2) What size fitting is on the end of the distribution tube. Looks like 3/4" to me but what thread are they normally? (NPT etc) Thanks in advance!! :drink: |
Fixx
I would say -12 but to be sure here's a chart..
http://www.gre6.com/ansize |
I used 12AN
How do you go from the T-Stat housing with about 22mm diameter on the outlets to the AN hose (-12) if it's ~18mm? Or do you need to modify the t-stat housing for an AN fitting (weld on?)
My current hose is 22mm ID (AN-16?), would reducing it to -12 possibly result in an increase in water pressure? If so, where is the best place to plumb in a pressure dump? I'm thinking of the ports at the back of the intake manifold into a T then dumping overboard. Any other suggestions? |
Originally Posted by Ghostrider
(Post 3275718)
My current hose is 22mm ID (AN-16?), would reducing it to -12 possibly result in an increase in water pressure? If so, where is the best place to plumb in a pressure dump? I'm thinking of the ports at the back of the intake manifold into a T then dumping overboard. Any other suggestions? http://www.eddiemarine.com/store/car...l&p=11552&c=40 |
I just run 1" hose from the thermostat to the exhaust. -12 is only 3/4" ID and I have found it to small in some applications. The 1" hose is a very easy setup and much cheaper than an hose.
Eddie |
Thanks all!
I run 1" at the moment and I'll need to find an adaptor or make one to fit the 1" pipe to the threaded fitting on the distribution tube I guess. Cheers, John :coolcowboy: |
Should be 3/4" npt on the exhaust distribution tube. Check with CP Performance. They have some SS fittings that are 3/4" npt X 1" hose barb.
Also, the OD of the 3/4" npt fitting is right at 1". I have used jsut a 3/4" npt nipple and slipped the hose on it in a pinch. The threads actually do a good job of giving the hose something to bite into. Eddie |
| All times are GMT -5. The time now is 02:07 PM. |
