Tuning help pls >
Tuning help pls
Tuning help pls
Old 12-25-2010 | 11:49 AM
Default Tuning help pls
Just built my 540 and need help dialing it in.
Where can I put an o2 sensor. I have stainless marine exhaust
Flying tomato
Flying Tomato is offline
Old 12-25-2010 | 12:12 PM
Smitty's Avatar
Is your exhaust a header pipe style or manifold?
Smitty is offline
Old 12-25-2010 | 12:57 PM
Default More info
Non-header type
I don't see any place to weld in an o2 sensor????
Surely there's a way.
Old 12-25-2010 | 03:13 PM
Sporl Performanc's Avatar
Ron Sporl Performance
It needs to go in the stainless riser closest to the manifold, this is double jacketed, so the best advice is to send it back to weld in the 0.2 bung. It should cost you less than 50.00!
Ron Sporl Performance 504-616-6005
Custom High Performance Marine & Racing Engines,Full In House Machine Shop,Custom Rigging & Other Performace Applications. www.ronsporlperformance.com
Sporl Performanc is offline
Old 12-25-2010 | 09:53 PM
Smitty's Avatar
Get a spacer plate made to go between the manifold and riser and put the sensor there. Make sure it is in far enough to be fully exposed to exhaust flow other wise the sensor will not read at high rpm.
It will work, I have a friend that did it.
Smitty
Smitty is offline
Old 12-25-2010 | 11:14 PM
Default fIXX
Email Me,i Have A System That You Dont Need To Weld Anything Unless You Want To Leave The O2 Sensor In At All Times To Monitor Your Afr's..
FIXX is offline
