maching vortec heads >
Old 12-30-2010 | 05:38 PM
JimV's Avatar
Originally Posted by innerrage
its a 350ho vortec with msd ignition 8.5 wires 8m blue ignition box holley 650 edlebrock performer rpm intake and revolution marine 4inch aluminum wet exchaust with a gaffrig air cleaner the motors only has about 15hours on it and i got a set of ss full roller rockers for it to put on
Sorry, I thought you were talking big block. The small block heads are very workable as well. I'm working on a set right now. You may want to use a 1.6 rocker on the intake side.
JimV is offline
Old 01-11-2011 | 10:55 AM
JimV's Avatar
Here are some flow numbers from a stock head:
Lift....................CFM....................... CFM
Intake EX
.2......................127.....................10 1
.3......................185.....................13 8
.4......................222.....................14 9
.5......................216.....................15 5
.55....................215.....................157
The intake port peaks at .4 and looses air after that point.
The exhaust poops out at about the same lift. Meaning there is an 11 cfm increase between .3 and .4lift and a 6 cfm increase between .4 and .5.
After some port work with the same valve:
Lift..............CFM...............CFM
Intake Exhaust
.2...............126.................111
.3...............191.................152
.4...............236.................178
.5...............242.................184
.55.............246.................186
.6...............248.................187
If I were to go to a 2.02 I would expect a gain on the intake at .4 and higher but would need extensive bowl and short turn work. Not a bad gain for stock valves. An added gain would be to increase cam lift to .550 to take advantage of the extra airflow at higher lifts.
Attached Thumbnails maching vortec heads-vortec-heads-002.jpg   maching vortec heads-vortec-heads-001.jpg
JimV is offline
Old 02-12-2011 | 09:06 AM
thanks i wish you were closer
innerrage is offline
