anybody have gasket part #'s for bottom end?
so i'm going through and checking everything on my 1990 Mercruiser 454 MAG gen IV since its out of the boat so i will need oil pan gasket, timing chain gasket, intake,exhaust, head gaskets ETC . does anybody have part #'s for these in a brand like felpro so i can order them from someplace like summit etc? or will any BBC gasket work on those areas except for need of a specific marine grade head gasket??
also, anybody have a part # for the stock oil pump, or a melling pump that will just bolt in without requiring me to modify pickups? i figure i may as well replace it while I'm in there since it keeps the whole motor alive!
thanks!
thanks!
You should be able to at least get part numbers here if not the actual parts...?
http://www.mercurypartsexpress.com/us/parts-search.html
Fel pro makes marine specific gaskets. No need to buy from mercury as they are just more expensive. Any gaskets for a gen IV bbc will work with the exception of the head gaskets which should be marine.
Just call summit and talk to someone on the tech line, they will get you the right stuff!!!
This is a marine head set at Summit.http://www.summitracing.com/parts/FEL-17246/?rtype=10
You should be able to get all the others locally in Fel Pro. You can also get an oil pump at a local store. Most carry Mellings.
Nappa carries all the marine gaskets also.
1 Post
Fixx
Call bob @ Performance gaskets,he has everything but the oil pan gasket which is just the standard gm 454 oil pan gasket which you can get at your local dealer for about 30 bucks..
262-677-4691
262-677-4691
All I was saying guys was he could get part numbers, most places can cross reference, I agree Merc stuff is usually more expensive, but when your talking gaskets there is not much difference.....
