On for the cab gurus >
Old 12-29-2010 | 10:25 PM
Default On for the cab gurus
My bg 850 has no power valve in the secondaries. Motor is not getting enough fuel when the secs open up. Can a pv be added??????? * Has anyone else had the same prob???
Motor is built 540 with 10/1 comp, good heads, bob m camshaft 238/246 .625/.649. * * Fuel supply has been upgraded to1/2 inch everything with steady 7psi
Flying tomato
Flying Tomato is offline
Old 12-29-2010 | 10:47 PM
Throttle Fever's Avatar
On the 850 it should have a plug in the metering block. Remove the plug and install a power valve, then jet accordingly.... Pete
Throttle Fever is offline
Old 12-29-2010 | 10:53 PM
Just jet the secondairies 4-6 jets larger than you have now, forget the powervalve in the sec. and if you still believe your not getting enough go two sizes larger and try again until you reach the desired result...............................Robertjr..... ......................
Robertjr is offline
Old 12-30-2010 | 01:49 AM
Agreed. 90% of the time, if you are into the secondaries, the vacuum will be down and the powervalve will always be open anyway. Just jet it richer.
Griff is offline
Old 12-30-2010 | 08:24 AM
You also need to see what the high speed air bleeds are. They may be too small and you may not be able to put enough jet in it. What are the secondary jets now? What are the high speed air bleeds?
Eddie
Young Performance is offline
Old 12-30-2010 | 09:57 AM
QUOTE=Young Performance;3285574]You also need to see what the high speed air bleeds are. They may be too small and you may not be able to put enough jet in it. What are the secondary jets now? What are the high speed air bleeds?
Eddie[/QUOTE]
I agree with Robert and Eddie, as in the best way to go. I was just answering your power valve question. Run the same carb's w/o power valves (in the rear). I did however setup on the air bleeds (as Eddie mentioned) and the squirters. Then rejetted in steps, (468" single planes, 600"lift rollers) Think I am at 80 front (with power valve) and 88 rear on jets (think?). Never ran that small of a carb on a 540" motor myself (1050 works great, have one on a 509" motor tunes easy and dynoed out at 580 hp). So my setting are just a baseline on mine (smaller cube engines) .. Pete
