Patriot performance heads ? >
Old 12-30-2010 | 10:07 AM
Default Patriot performance heads ?
Now that I know Pro comp heads are junk has anyone used Patriot heads? They are made in USA and fairly reasonable about $1400 assembled a pair on Summit.
sirfartsalot is offline
Old 12-30-2010 | 11:14 AM
I used a set 2 years ago on a 540. They were the "freedom series"? I had them lightly ported and intake matched. The motor made over 680 HP. They been on ther same engine and running great for 2 seasons now. I would recommend them.
kreed is offline
Old 12-30-2010 | 12:58 PM
Default Patriots
I have owned both. I am no expert but this is what I observed
1. Patriots casting is much thicker and total weight is 5-6 l s heavier per head
2. All the valves line up perfectly with the pushrods/guideplates on the patriots. Not so on pro junks
3. Patriot has a plant that you can call for tech help that is very good (ask for Stephen)
4. QuAlity is much better (my opinion) on the patriots
5. Make sure you change out the exh valves to inconel
6. Performance is super on both
Ft
Flying Tomato is offline
