540 piston rings, gapless or standard ????? >
Old 01-04-2011 | 08:19 AM
Default 540 piston rings, gapless or standard ?????
I am repairing my 540's that had piston damage. New block, new JE pistons, 9.2:1 CR, Eagle rotating assy. I am now ordering rings. I have built many high perf engines, but never used Total Seal's gapless rings on anything, automotive or marine. Are they worth the extra cost ? If not, what do you reccomend in a file to fit, Total seal moly ? , Speed Pro ? etc
doctor_ratz is offline
Old 01-04-2011 | 09:18 AM
Default Fixx
i would try and match what was in the old engine if your only going to be rebuilding one of the pair,including the crank and rod's..if your using a heavier crank in the new motor it will be a slug compared to the other engine,its always best to rebuild in pairs.
FIXX is offline
Old 01-04-2011 | 10:37 AM
I've used the total seal gapless rings in auto applications for the street quite sucessfully - leakdown numbers are amazing, and almost no blowby. I know of several auto racing engine builders that swear by them.
That said, I have no idea how they might work in a marine engine - extreme load for long periods unlike a auto engine. I'd call total seal for thier take - the race versions might work quite well.
apollard is offline
Old 01-04-2011 | 01:03 PM
Yes, I am tearing both down. Same / Same on internals. Just not sure about the ring selection. Gapless is an interesting concept, but I have heard both good and bad.
Old 01-04-2011 | 05:57 PM
Default Fixx
you can go either way,if you plan on adding blowers in the future i would go gap less,if not then a plasma molly would be a good way to go..
FIXX is offline
Old 01-04-2011 | 08:42 PM
Smitty's Avatar
I used gapless in my first pair of motors that ran for 3 seasons till I broke one. Then I went to std rings to cut costs and I am regretting it now. Less than 2 seasons and I am losing seal and power and the first motors had same comp as new after 3 seasons.
Smitty
Smitty is offline
Old 01-04-2011 | 11:12 PM
Total Seal Gapless rings are the ONLY rings that I will use..........period. Just make sure the machine shop knows what they are doing and are able to provide the correct cylinder wall finish. If they don't know, go elsewhere or choose a different ring.
Eddie
Young Performance is offline
Old 01-05-2011 | 09:37 AM
Eddie
What type of finish?
Pokher Ace is offline
Old 01-05-2011 | 09:47 AM
Ra 10-20 with the proper degree of crosshatch (approx. 45*)
Old 01-19-2011 | 10:32 AM
eightsecmopar's Avatar
What ring sets do you use? Max seal sets or something different? Thanks for the info. Normally aspirated application.
eightsecmopar is offline
