Trim tab and outdrive fluid change >
Old 01-13-2011 | 01:38 AM
Merc recommends 30 wt oil.
Griff is offline
Old 01-13-2011 | 10:56 AM
Is there any special process to doing this, other than just sucking out of the reservoir and swapping fluid?
xsboost525 is offline
Old 01-14-2011 | 12:01 AM
Really, unless the oil/fluid is real dirty or water contaminated, I wouldn't even bother changing it.
If you do though, just run the tabs or drive up and down several times to bleed out any air.
Griff is offline
Old 01-14-2011 | 10:25 AM
Im one of those that even if you tell me you just changed something, I'd rather change it again to know it was done right and when it was done. It doesnt look that dirty per say, but just rather do it to know its good to go. Thanks guys!
