Crossovers ? >
Crossovers ?
Crossovers ?
Old 01-13-2011 | 06:53 PM
bcfountain's Avatar
Registered User
i never used a relief valve on my set up untill i changed drives.the one on there now has a low water pick-up in the noise cone of the drive.the pressure more than doubled.like said,put a gage on it,you will be suprised.
bcfountain is offline
Old 01-14-2011 | 12:27 AM
Originally Posted by MILD THUNDER
I think the circulating pump might help regulate in psi in the block. You can have high water psi due to the speed of the boat, hull pickup design, etc. Or you can have high water psi from a restricted exhaust water flow, etc. Some boats have relief valves in the sea strainers, to help protect from psi spikes when re-entering the water. The high psi from this can POP hoses off the strainer, pickup, etc.
Most scenarios though is too high of psi in the block, which can blow headgaskets and or intake gaskets.
My thoughts on a lot of high water psi complaints, is from exhaust that restricts water flow. The merc sea pump design puts out A LOT of water. The more you restrict the flow, the more psi is going to build up. My water psi is about 20 psi wot. My exhaust water dumps are 3/4". I bet if I reduced the dumps to say 3/8", it would drastically increase water psi in my block.
Ok. Then I might have high psi already even though I dont use any thermostats. I mean if the bottleneck is the exhaust...
Anyway, I will install relief valves to be safe. Thanks for all info guys!
totto is offline
Old 01-14-2011 | 09:04 PM
thanks for all the good insite guys... After reading all that and doing some shopping I thing i am gonna stock with the circulation pump set up that i have...
theadamv1 is offline
