Broken whipple
Broken whipple
The bolt that holds the pulley on my whipple broke off while out on the water today. Luckily I was able to idle back to the ramp about 3 miles. Anyway, I was able to get the broken piece of bolt out but am a little confused that the pulley doesn't seem to be keyed. It is just a smooth mating surface. Am I missing something? Is just the bolt able to hold it without slipping?
Yes, the bolt is the only thing that is holding it. It's a friction drive. The newer ones use dowel pins or flats on the pulley adapter. If you have a socket head bolt that holds the pulley adapter on, then you need to switch over to the stud. It's much less likely to break.
Eddie
Eddie
