Steering helm going out...replace or go hydraulic? >
Old 01-20-2011 | 09:10 AM
Thanks for the links.
whats the big difference in between the first one, and Mayfair deluxe kit?
I have a Bravo xr, with single ram.
thanks again.
cabin fever is offline
Old 01-20-2011 | 10:13 AM
c_deezy's Avatar
Looks like the deluxe comes with the remote reservoir.
Which personally I didn't use, I don't see the need unless you are running two pumps. Once the system is bleed, the fluid volume will not change and as long as you have a decent cooler you should have no issue with heat.
c_deezy is offline
Old 01-20-2011 | 10:34 AM
waterbum's Avatar
Originally Posted by cabin fever
I have Hydraulic steering, but its not "full" hydrualic. Is there a kit to make it complete, or do you have to start all over?
If you already have hydraulic rams to the drives with cables on the inside (cable over hydraulic), you can replace the cable helm with a hydraulic helm, add hoses, filter, etc. and have a full hydraulic system.
I did this about 4 years ago using what was already in place and just adding the remaining components. Was just under $1k for the new helm, fittings, hoses, filter, etc. It's a do-it-yourself job but somewhat time consuming by the time you move stuff out of the way to get to the inside of the transom, assemble,route, and clamp the hoses.
It was well worth it! I would recommend it on any performance boat.
waterbum is offline
Old 01-20-2011 | 10:48 AM
I never did see a response on motors.... Do they have to be pulled to install these systems or can you easily get to everything with them in
FuelinAround is offline
Old 01-20-2011 | 10:56 AM
waterbum's Avatar
Motors were left in. We removed the exhaust / tailpipes and some other pieces to get to the transom easier. I suppose if you're real skinny you may not have to remove anything.
waterbum is offline
Old 01-20-2011 | 11:07 AM
you can do it with the motors in the boat. there are 4 lines that run to the column. pressure return left and right turn. you need to get to the power steering pump and oil cooler.
violator is offline
Old 01-20-2011 | 11:38 AM
excellent
thanks for the replies fellas.
