Transmissions >
Transmissions
Transmissions
Old 01-21-2011, 10:01 AM
Default Transmissions
Do most transmissions use a drive shaft or Cardan joint? Or do some just plug on to the outdrive shaft? any photos out there? Thanks
ken sampson is offline
Old 01-21-2011, 10:43 AM
Some have drive shafts especially in a staggered engine set up. Usually the cardan joint is located on the input shaft of the drive to allow for trimming of the drive. Here you can see one on a TRS drive. The splined input shaft will plug into the tail stock of the transmission.
http://cgi.ebay.com/ebaymotors/Mercr...tem 254fc4ba57
picklenjim is offline
Old 01-21-2011, 10:52 AM
tcelano's Avatar
The outdrive has a double cardan joint on the input shaft to allow it to operate at high angles with no pulsing, like a constant-velocity joint.
If you have a driveline setup like those used with extension boxes, then the transmission has a standard spicer flange, and the jackshaft has standard single u-joints on each end. This requires a tailstock assembly that is just a big bearing with a flange on the front and a socket for the drive input shaft on the aft side. I'd take pictures of mine, but you aren't going to see much...
tcelano is offline
Old 01-21-2011, 01:10 PM
How about the shaft on the trans that goes into the bell housing would anyone know how far into the bell housing this should be? 2" or 2-1/4"?
