What Octane
Old 05-17-2002 | 01:04 PM
GregP's Avatar
Default What Octane
I've always used 93 octane in my motors, but am wondering if I could get away with 89. Tthe fuel dock at the end of my creek only has 89, the nearest 93 is down the river a bit. Last time out one of the two places for 93 had broken pumps and I was REALLY low on fulel.
The motors are 454's with 9.8:1 static compression and the cams have 235/245 @.050 duration, Iron GM heads.
How much compression is anyone running against 89 octane?
-Greg
GregP is offline
Old 05-17-2002 | 01:16 PM
Iron heads and almost 10:1. Stick with at least 92 unless you want to retard the spark advance.
My $0.02
Gary
Gary Anderson is offline
Old 05-17-2002 | 01:24 PM
GregP's Avatar
Hi Gary, glad your still around.
Forgot to mention that I do run a fair amount of advance, 35-36 degrees total all in by a little under 3000 RPM, and around 18-20 initial (I set the total and let the initial fall where it may). I've got the MSD's set to the shortest advance curve I could.
-Greg
GregP is offline
Old 05-17-2002 | 01:31 PM
OK, 10:1 iron heads, and 36 degrees? Damn, I would stick with 93, cheap insurance.
I had to put 89 in my 525SCs once (late night fill up) and I was scared to push over 1lb boost. Bad thigs happen when you start to detonate.
Gary
Old 05-17-2002 | 03:02 PM
You may get away with using 89 if you throw some octane booster in with it. Watch your plugs for little aluminum beads!!!
WETTE VETTE is offline
Old 05-17-2002 | 04:04 PM
jdnca1's Avatar
Also if you just cruise and don't hammer on it 89 should be fine
jdnca1 is offline
Old 05-17-2002 | 10:57 PM
mcollinstn's Avatar
Does anybody have a rule of thumb for degrees of retard for dropping from 92/3 to 89 or to 87 octane?
My MSD Digital boxes have a retard that can be wired to a switch. I was thinking of using it as a "cheap gas" retard but don't know where to start as far as degrees to retard.
Figured I would monitor it and see if it affected my cruise fuel economy. If not, I would intentionally use cheap gas on long (over a tankfull) cruising trips.
mcollinstn is offline
Old 05-18-2002 | 11:50 AM
GregP's Avatar
Guess I'll keep running the 93 (it really isn't much cost difference) and hope I don't need to use 89 to "get me home" anytime.
I'd hate to have to pump out 200+ gallons of fuel I can't use. It would take a LOOOONG time to burn that much waste fuel in the lawn mower
-Greg
GregP is offline
jonholmb9
10
05-13-2004 08:08 AM
36spectre
08-04-2003 09:52 PM
thundergreg
3
08-01-2003 02:44 PM
zog02
22
02-04-2003 07:46 AM
THRILLSEEKER
6
06-07-2002 03:17 PM
