Whipples
Old 05-29-2002 | 09:05 AM
wilerty
I have a Whipplecharged 502 Mag EFI and use a drilled out thermostat. In the 1000 Islands the engine runs at about 120 degrees in the spring ... reaches 140 to 150 in the summer. I also use an offshore water pickup and strainer.
Old 05-29-2002 | 01:22 PM
Quiet Storm's Avatar
Cayfomula,
What spark plugs are you using? I had the carbs set up by Teague for the superchargers. They are 750 Holley's. I am going to install thermostats. The motors need some heat.
Wilerty, do you remember the size holes that were drilled in your thermostat?
Quiet Storm is offline
gregsweeney
09-11-2009 11:04 PM
thisistank
02-06-2008 11:33 PM
docmanrich37
07-07-2005 06:22 AM
MJM
03-01-2005 08:42 AM
Kato33
Baja
0
09-15-2004 06:15 PM
