Max Speed 29 Scarab >
Max Speed 29 Scarab
Max Speed 29 Scarab
Old 01-22-2011 | 09:30 PM
Default Max Speed 29 Scarab
Hello all I'm trying to get some help here. I have a 1997 29 Scarab and live in Bermuda. I recently replaced my original 350 mag motors with two 383 mag stroker engines. I have bravo one drives with the same standard props on the boat it came with. After some testing and running in about a 3' chop I had the boat running around 65mph. I want to know with this set up should I be expecting much more on my top end? I'm considering some new props and possibly a gear ratio change. Any help or feed back would be appreciated.
Chris A Smith is offline
Old 01-23-2011 | 07:47 AM
Can you give more information. What RPM is your engine set up for, what is your RPM at WOT? Can you give a few details about your engines and what do you estimate the HP at?
I used to know a guy that had one with twin 454's about 420 HP each. Also what prop are you running? His boat ran about 68-70 on the GPS.
jeffswav is offline
Old 01-23-2011 | 07:10 PM
Details, possible help, need details? Drive gear ratio? rpm? current prop type/pitch? Happy meter speed or GPS?
Sport 280 is offline
