Sea Water Pump >
Sea Water Pump
Sea Water Pump
Old 01-23-2011 | 12:40 PM
Default Sea Water Pump
Hello, I have a 2004 Shockwave 21 Step Skier with MX 6.2 MPI. I had an issue with low engine operating temp of 130 with a normal op temp of 180 in a 75 to 80 water temp environment, I run the lower Colorado River, Lake Martinez area. Chose to change out the thermostat, while doing that chose to inspect the sea water pump, impeller needed to be replaced, although not in BAD shape, questioned the housing, took it to Yuma Marine. They said they could mill the face plate to remove the wear and install a new impeller, sounded good to me. Put it all back together and now the belt wants to walk off the idler and pump pulley (it doesn’t, but it wants to), (Yuma Marine says that they get three cuts without any issues) I then attempted to shim the pump to get it in exactly the original location. No shim combination worked.
Question #1) Did I bend the pump bracket with initial reinstall of the altered pump?
Question #2) Do I need a new bracket and re-shim the pump?
Question #3) Is their pump repair widely accepted?
Question #4) Should I have replaced the whole pump assembly?
Help, thank you!
bellaveloce is offline
Old 01-23-2011 | 03:42 PM
What part did they mill?
http://www.perfprotech.com/store/ass....aspx#assembly
Number 1 or number 9 ?
Milling should not have changed the pulley location. You probably did not bend the bracket unless it appears that you did some how. My guess is if they milled part number 1 that they had to remove the pulley and shaft. The pulley is press fit on the shaft to a certain distance. Sounds like they pressed it on to far or maybe left out part number 6 the tolerance ring which would allow it to press on too far. I have my water pump bracket shimmed out from the block and have never had any problems doing so. Sounds like you need to take it back and have them check the pressed on distance or if they left the tolerance ring out or find the correct thickness shims you need.
picklenjim is offline
Old 01-23-2011 | 06:51 PM
I am pretty sure they milled only the cover plate #9, I will have to verify this, will have to check the other things you mention as well. Thank you!
