AN Sealing on pipe thread adapters >
Old 01-31-2011 | 10:59 AM
Registered User
Default AN Sealing on pipe thread adapters
I ran som AN lines for oil and powersteering to an oil cooler. What product would you recomend using to seal the pipe thread adapters. Obviously teflon tape and oil dont have a long happy life together. Any suggestions?
Thanks!
bigblue is offline
Old 01-31-2011 | 12:25 PM
Locktight brand sells a pipe thread sealer that would perfect for your needs. Not sure of the name off hand ,but a quick search of their site would find it.
Darrell.
DMOORE is offline
Old 01-31-2011 | 01:31 PM
get yourself a can of Highside LeakLock
Leak Lock is a state-of-the-art high strength, pipe joint sealant consisting of chemically resistant film formers, plasticers, reinforcing fillers and solvents .
A resin based brushable paste which remains permanently flexible, adheres to internal surfaces and fills voids
Ideal for metal and plastic materials subject to extreme vibrations
Effective in temperatures from -200ƒF (-93ƒC) to 400ƒF (204ƒC), full vacuums and pressures to 10,000 PSI
Leak Lock can be used on all metal or plastic materials, including but not limited to, aluminum, aluminum alloys, cast irons, copper, copper alloys, (brass, bronze, etc...), magnesium and magnesium alloys, carbon steels, stainless steels, galvanized surfaces, PVC, CPVC, ABS, fiberglass, black polypropylene, and kynar. Leak Lock should be applied to threaded joints, flanged joints, gasket surfaces and all mating surfaces where a fluid-tight seal is required.
Leak Lock seals a broad range of chemicals including all refrigerants such as R-12, R-22, R-502, R-134A, etc., all CFC, HFC and HCFC refrigerants, petroleum products, natural and manufactured gases, steam, water, air, etc. No other sealant offers the application range of Leak Lock. Use alcohol as a cleansing solvent prior to setting.
Available in 1 1/3 oz. tube; 4 oz. & 16 oz. brush top plastic jars; 1 gal. can
parts store or local Grainger
Old 01-31-2011 | 04:07 PM
Default Fixx
Yep, leak lock,,i perfer the gold but this works as well..
http://cgi.ebay.com/Leak-Lock-Joint-...item1e5be8e41b
FIXX is offline
Old 01-31-2011 | 04:10 PM
unbelievable stuff ah FIXX ??? sure wish Fastenal would sell it in a lesser quanity then a case ..
Old 01-31-2011 | 08:49 PM
Default Fixx
Yes it is,
FIXX is offline
Old 02-01-2011 | 06:25 AM
For $26 shipped 200 miles it better be gold
1BIGJIM is offline
Old 02-01-2011 | 06:49 AM
Registered User
Thanks guys!!!! Grainger is a place i pass almost daily. I think I will be stopping by! I like to see what i am buying. Unfortunately I may end buying something else i may or may not need while I am there!!!
bigblue is offline
Old 02-01-2011 | 06:56 AM
Dave M's Avatar
Veteran: Navy
Locktite 545 is what I've used for steering fittings.
http://www.amazon.com/Loctite-Sealan.../dp/B000FONOM2
Dave M is offline
Old 02-01-2011 | 07:15 AM
But what good is it if ya cant get it
Currently unavailable.
We don't know when or if this item will be back in stock.
Loctite 32429 545 10ml Thread Sealant for Hydaulic and Pneumatic Fittings
by Loctite
Be the first to review this item Like 1296566024 false -1 0 0 0 (0) |Share
