93-97 99-02 454mag where is 98?
a few places iv looked online for superchargers or any motor performance part they list either 93-97 or 99-02 454 mpi mercruiser....what happened to 98? my motor is a 98 did i get the odd ball year? is there a difference in a 97 98 99?
96-97 I think was the transition year. They ditched the VST tank and lift pump, and went to the cool fuel system. I think that is also when the serp belt was used.
Here is a manual for the 98. http://www.mercruiserparts.com/selec....asp?type_id=8
1997 was the transition year for the cool fuel system and I believe 1998 was the transition year for the serpentine belt system. I have a 1997 with the cool fuel system and v-belts.
My 97 had the cool fuel system but no serp belt.
Here's the '98 right here...
http://www.mercruiserparts.com/selec...M+454+V-8+1998
Check to see if your serial is in that range.
Oh, and don't assume that if your hull is a '98 that your motor is too.
98 is an odd ball year. It is the rear they transitioned from V-belt to serpentine and from a Mefi 1 to Mefi 3. Some engines had a V belt and Mefi 1, some had Mefi 3. The same with the serpentine, some had a 1 and some a 3. The only way to tell is by serial #.
If you are looking to supercharge it and you have a Mefi 1, than plan on replacing it with a Mefi 4 ecm and harness. If you have a 3, then you are good to go. The Mefi 1 has no way to tune in boost. All of the tuning is basically done with fuel pressure and injector pulse width.
Eddie
Eddie
Eddie
Eddie
Eddie
