HELP! Dead Battery, Can't Open Engine Hatch >
Old 02-15-2011 | 01:29 PM
Is it the baja you have listed in your avatar? Baja installed slip joints on most of their boat lift hatches, with a pin or bolt for emegency opening. Have you tried lifting the hatch by hand?
4bus is offline
Old 02-15-2011 | 01:32 PM
Originally Posted by hopper75
Left the boat sitting too long and now can't open the engine compartment lift to access the batteries due to a dead battery. Will a cigarette light style booster/charger do the trick or do I need to take more drastic measures?
You might check under your rear bench and see if there is a pos/neg post/bolt that you can hook a charger to. My 02 252 Islander was set up this way specifically because of the problem you're having. There was also an option where you could manually pull up on the sunpad cover just enough to reach under there to pull the pin that attaches the lift actuator to the sunpad cover.
Busta is offline
Old 02-15-2011 | 09:56 PM
Yeah my Liberator had a hatch behind the back seat that would allow me to pull the pin for that hatch lift mechanism for manual lifting
rexcramer1 is offline
Old 02-15-2011 | 10:00 PM
Originally Posted by mrfixxall
And once you get the hatch open, install a onboard charger and all you will have to do is plug it in..
+2
Old 02-16-2011 | 06:10 PM
US1 Fountain's Avatar
Ginger or Mary Ann?
Just don't leave the plug for the charger tied up nice and neat, inside the engine compartment.
US1 Fountain is offline
Old 02-16-2011 | 11:05 PM
cigboat1's Avatar
When you get your hatch up and every thing is running ,I would suggest that you purchase a remote power outlet from
Eddie Marine Inc. Mount it under the back seat so you can get at it. Cost is about $45.00 plus the cost of the wiring .... You can connect jumper cables directly to this power outlet.Box is about 3X5 inches and has a nice flip door on it ..Model # is 302-31W Never have to worry again about any dead batteries....Good luck
Jim
WWW.eddiemarine.com
cigboat1 is offline
Old 02-17-2011 | 01:20 AM
Randy Nielsen's Avatar
When Louis rigged my boat he ran 2 extra wires directly from the hatch motor to where the battery switch is mounted with weatherproof ends to hook up a cordless drill battery works great for that purpose
Randy Nielsen is offline
Old 02-17-2011 | 10:45 AM
Ginger or Mary Ann?
All these ideals are good, as long as the hatch ram itself isn't what goes bad. Then all the chargers and remote wiring ain't goinna do squat. Access to be able to pull a pin or the lift that has the slot will be your savings grace.
Old 02-17-2011 | 11:00 AM
And a pull strap if you cant get under the edge of the hatch to lift it
Old 02-18-2011 | 01:46 PM
Thanks to everyone for the great ideas! Got under the dash today and was able to hook the trickle charger to the leads from the cig lighter, so far so good, seems to be taking a charge.
hopper75 is offline
