Winterization 496 Mag HO >
Old 02-15-2011 | 06:49 PM
Default Winterization 496 Mag HO
I have a 35' Fountain with the 496 Mag HO's. The boat was winterized and sitting on a lift. The lift deflated and the boat went into the water. Does the boat need winterized again after I get it out of the water?
goirish is offline
Old 02-15-2011 | 07:03 PM
Velocity Vector's Avatar
Crazy Energy
Thats a bummer, You should be good if all you are doing is getting water out of it. 496's are closed cooling with antifreeze
Velocity Vector is offline
Old 02-15-2011 | 07:05 PM
Just wanted to make sure the water would drain back out of the outdrive.
goirish is offline
Old 02-15-2011 | 07:14 PM
Does it have strainers? Depending on how for down it was. They could have filled.
redbud35 is offline
Old 02-15-2011 | 07:28 PM
not sure what strainers are?
goirish is offline
Old 02-16-2011 | 01:46 AM
tcelano's Avatar
Where do you live? In many places, the risk of a hard freeze may be over by now. Is it salt water? If so, you'd be good to flush stuff out the raw water just to limit corrosion.
Sea strainers, if you have them, are usually a big cannister looking device with hoses running in and out, and usually a clear bolted lid. You may not have them. You don't have transmission coolers, but you may have a power steering cooler. If you did not start the boat, it's unlikely any water got to the header/mainfolds.
While we are on this topic, what is the consensus on regular raw water cooled motors for winterization? After running anitfreeze into them, leave the blocks full or drain them down?
tcelano is offline
Old 02-16-2011 | 12:03 PM
I leave mine full to reduce corrosion. The antifreeze I use has a rust inhibitor additive.
4mulafastech is offline
Old 02-16-2011 | 01:46 PM
+1
As long as the antifreeze is rated to the temps where the boat is stored, that is.
A.O. Razor is offline
