Stellings VS CMI >
Stellings VS CMI
Stellings VS CMI
Old 02-24-2011 | 01:32 PM
Default Stellings VS CMI
Well it’s about time to make my decision on exhaust for my 604CI motors. I am looking at both of these companies any input? I was also looking at the KE aluminum. however just no bling.
ken sampson is offline
Old 02-24-2011 | 10:51 PM
Coolerman's Avatar
PF Marine
KE's make much more bottom end, and should be around the same on the top end on your motors. This is what our testing showed us when we originally made those headers under the name PF Marine. Just make sure you have a good water supply through them with air pop-offs on your strainer.
Coolerman is offline
Old 02-25-2011 | 05:22 AM
The KE manifolds are not pretty, but they are also zero maintenance for many years. The more Hp the more you should consider the cast manifolds. When you pump a lot of BTU's through the SS the fight begins with cold and hot, the cast manifolds will win every time and worst case you lose 25 Hp and and can ride all summer
James is offline
Old 02-25-2011 | 06:08 AM
I can not go with the KE on tripples. I thought they for bravos?
Old 02-25-2011 | 06:14 AM
Stelling is an expensive, but superior product. If moneys not an issue, go Stellings.
kreed is offline
Old 02-25-2011 | 04:49 PM
HUSTLEthis's Avatar
x2......ours were made in 03...knock on wood
HUSTLEthis is offline
Old 03-30-2011 | 04:23 PM
I can help you with the CMI's or the Stellings. I saw your other thread and I am currently converting a 388 Hustler from Bravo to Arnesons and Ilmor V-10's.
brian41 is offline
Old 03-30-2011 | 08:11 PM
Look for the post I have called Exhaust Dyno... It shows real world results for what your looking at. Should help you make up your mind!
endeavour32 is offline
