Sea pump assembly lube? >
Old 02-24-2011 | 02:02 PM
Default Sea pump assembly lube?
Hey guys,
Whats the best thing to lube new rubber sea pump impellers with prior to install? Soap?
Magic1 is offline
Old 02-24-2011 | 02:13 PM
Ted G's Avatar
Dish soap works fine.
www.cbpba.com
Ted G is offline
Old 02-24-2011 | 02:16 PM
c_deezy's Avatar
A ty-wrap to roll the vanes over so it goes in easier. No lube necessary.
c_deezy is offline
Old 02-24-2011 | 02:40 PM
I was worried about initial start up, not getting it in the housing. The soap doesn't dry out and stick?
OK, thanks guys !
Magic1 is offline
Knot 4 Me's Avatar
White lithium grease.
Knot 4 Me is offline
Old 02-24-2011 | 03:08 PM
I use vaseline
JMPH is offline
Old 02-24-2011 | 03:22 PM
I just looked in Mercruiser manual. They say dish soap.
Thanks guys for the input. Just got one down!
Magic1 is offline
Old 02-24-2011 | 05:20 PM
Sydwayz's Avatar
Forum Regulator
Veteran: Air Force
Some of us use Dawn for flushing the engines after salt water use. I use it for SWP assembly too.
A zip-tie around the veins sinched down a bit works awesome to get the impeller started into the pump. Get it about 1/2 way in and snip the ziptie off. Then rotate the impeller the rest of the way in.
Sydwayz is offline
Old 02-24-2011 | 05:28 PM
I use Mercury 2-4-C grease, dish soap will work great if you are going to run the boat right away, if it may sit a couple of weeks before running the grease will not dry out.
Fountain Fever is offline
Old 02-24-2011 | 06:34 PM
Default Fixx
KY jelly ,, it really works..
FIXX is offline
