454 Mag
Old 02-24-2011 | 08:18 PM
Default 454 Mag
Hey guys I'm building my 454 and just wondering if I reused my roller lifters do they need to go back in the same hole they came out of I heard if not it will knock a lobe off the cam, is this true. Also one motor had roller lifters and the other did not is that a big deal.
Gettintipsy is offline
Old 02-25-2011 | 07:03 AM
Payton's Avatar
Charter Member #927
Well, the people that sell the roller lifters claim about 10hp with them. I know the one with the flat lifters need to be back on the same lobe. I've seen used sets of roller lifters for sale. So I am guessing ,no. just a guess.
Payton is offline
Old 02-25-2011 | 11:09 AM
I doubt you'd wipe a lobe off of a cam, but your lifters may wear faster if you don't put them back in the same order you take them out. I always try to match the parts to where they came out of, but that's just me.
As was mentioned, it's only 10hp. It's not really a huge deal that your other motor doesn't have roller lifters (if you only run one power steering pump you could run it off of the roller motor to balance things out if you really wanted to), but why not fix that while its apart? It's really not that big of an expense while its already torn apart. Also, if you're not going to change the cam on the non-roller motor, at least get new hydrolic lifters that match the cam. They're so cheap that its silly to reuse them, and most good cam kits come with them. That said, if you're going to spend $100 for new flats, why not spend $280ish for rollers?
wjb21ndtown is offline
Old 02-25-2011 | 12:35 PM
Well the deal is if one is a roller and one flat tappets then the cams surely have different specs. You cannot just change the lifters to rollers on a flat tappet cam. You will need to change it to a complete roller set up. Cam, lifters, pushrods, springs. More like a $1200ish conversion. The roller motor is probably making 30-40 more horse power.
And yes flats should deffinately go back on the same lobe.
picklenjim is offline
Old 02-25-2011 | 01:17 PM
And not worth it unless you have some honking a$$ big motor. At least not in my case for the money.
f_inscreenname is offline
Old 02-25-2011 | 06:30 PM
Thanks for all input guys
