-   -   600HP LS Marine Engine (https://www.offshoreonly.com/forums/general-q/248499-600hp-ls-marine-engine.html)
Plowtownmissile 03-02-2011 09:14 PM
Coming from a LS1 racing background, I can tell you that the motors are extremely reliable and MAST has been in the LS engine game long enough to know what they're doing. One motor I ran was a stock long block with boltons and a 150hp shot that had been raced every week for 70k miles. When the engine got a heads/cam swap, the cylinder bores still had the factory cross hatching marks with 105k miles on it and the motor has yet to die or make a noise.
The one thing I can say is to STAY AWAY from a aluminum LS1 block that has been big bore sleeved! MTI and ARE were doing this in the early days of the big cubic inch wars and alot of them ended up dropping sleeves. Go for a 6.0L iron block stroker or LSX block setup if you want bigger cubes.
daveintexas 03-03-2011 10:10 PM
I emailed this outfit to see what the pricing was. They replied very promptly. Here is what they had to say:
Final pricing has not been established, but we are targeting a complete engine with headers and accessories should be in the neighborhood of $30,000.00 retail. The engine will be rated for 6200 RPM max with 600hp and 570 Ft/lbs.
We should know much more in the upcoming months as we prepare for a late 2011 release date.
I will keep you on our contact list to send info as we get it.
Thank you for contacting Mast Motorsports,
Scott Mount
bor 04-13-2011 12:49 PM
1 Attachment(s)
Originally Posted by bigboat28 (Post 3339363)
How much you thinking?
Finaly on the dyno ,having lot of problems whit the calibaration but have now 540hp and 535 ft/lbs tq from 4000 to 5500 rpm but will find a little more after the fine tuning .
I think the cmi's take some hp because there 's no murch collector in what the ls engine likes .
4mulafastech 04-14-2011 12:27 PM
Thanks for the update. Is this engine going in your Phantom?
bor 04-14-2011 03:45 PM
1 Attachment(s)
Yes it comes in the phantom (uk) attach to a Blackhawk drive ,
the boat is normally outboard but I have it converted to inboard as well as the complete inside construction ,new stringers,transom and a bulkhead in the front,because that was very bad wood and mounted ,so basicly build a new boat .
bor 05-01-2011 06:14 AM
3 Attachment(s)
got the engine back from the dyno ,here the results ,have a pair lightning headers on the way to customise and see what they do whit our idears.
Raylar 05-02-2011 10:05 AM
Bor:
Might help a few people here on OSO if you would convert the numbers to HP and same for torque numbers shown in NM so they could relate to the outputs better here in the US.
thanks,
Best Regards,
Ray @ Raylar
FIXX 05-02-2011 11:08 AM
Fixx
411.0 hp
541.0 Tq
JRider 05-02-2011 11:30 AM
Cool setup...would like to see some numbers on a similar setup with forced induction. I can invision a 3.3 on top of that.
JRider 05-02-2011 11:31 AM
