350 upgrade question >
Old 03-02-2011 | 05:51 PM
Default 350 upgrade question
I have an 86 baja force 220 with a 350. I was looking to get a little more power and I saw a set of vortec heads on cl for 100 bucks. So I'm gonna buy them but I'm really not sure what intake and carb to buy. Also the heads have a 1.5 ratio which I believe is stock so I don't foresee any problems unless someone here can enlighten me. Otherwise any suggestions on an intake and carb
amitchell001 is offline
Old 03-02-2011 | 06:42 PM
Default Fixx
what cc heads?? do your homework before you buy,get casting #'s and see what the chambers are in cc's..when changing to vortec heads make sure you use self aleigning rockers or you will loose a valve..
use a edelbrock intake.
http://www.jegs.com/i/Edelbrock/350/...FUmo4Aodm1dmVg
or if you want to save 100 bux go with professional products crosswind..same intake..
http://performanceparts.com/part.php?partID=113089
FIXX is offline
Old 03-02-2011 | 07:23 PM
Thanks for the reply they are 906 heads
