steering
Old 03-06-2011 | 04:57 AM
Default steering
HI all i have marine/machine steering on twins the drives are B1s the boat is 2001 the rams are external and has a large dia s/s tiebar conecting the drives on the out side my Q is do i still need the small dia tie bar inside the boat on the steering arms regards paul
paul buckner is offline
Old 03-06-2011 | 08:05 AM
blue thunder's Avatar
I left mine in place when I only had the add on hydro steering. When I went to full hydro I removed the inner tie bar.
blue thunder is offline
Old 03-06-2011 | 08:50 AM
Mbam's Avatar
Offshoreonly Advertiser
If you don't trim the drives at exactly the same time/rate/position having the inner bar puts stress on the gimbal, upper pin & steering arm. We remove it.
Mbam is offline
Old 03-06-2011 | 02:28 PM
Thanks blue thunder and Mbam, i will leave it off then
