Where is the 90amp fuse on Mercruiser >
Old 10-20-2019 | 01:12 PM
BUP
And not all apps have the 90 fuse either
Its a poor design plus in a poor installed location and the quality of that fuse is below average.
BUP is offline
Old 04-05-2020 | 01:50 AM
Originally Posted by BUP
And that is a 90 amp fuse on its way out and if its an efi engine what a way to knock out the ecm. Just reporting what I see very clearly.
Dear Bup,
last autumn the orange cable from the alternator to the startor burned. Maybe a caused by a shortage. I'll now change wiring to go via an isolator.
But now to my questions:
-Do you mean the ECM can be demaged or the ECM will not work, if the fuse is broken. I expect there's no voltage anymore on the engine, if this fuse is broken.
-would you recommend to leave that fuse away or to replace it by a better quality fuse, maybe installed on a more maintenance friendly location?
Thanks and cheers
Frank
FJ96 is offline
