Sea Water Pump KIT >
Sea Water Pump KIT
Sea Water Pump KIT
Old 03-09-2011 | 12:27 PM
Default Sea Water Pump KIT
Another question that may seem silly, but I will never know until I ask....
I have Bravo 1 drives on my boat and it has only been used in Lake Havasu. No I am wanting to take it out in the San Francisco Bay and need to know if need to change the impellers to the Sea Water KIT?
This is the kit I found:
How are Sea Water impeller any different then fresh water?
twoforone is offline
Old 03-09-2011 | 12:46 PM
BDiggity's Avatar
i am far from an expert, but i've never seen "sea water" impellars. I have seen salt flush kits you can install to then flush out the salt water with fresh once you are done for the day. I thought the salt only impacts the metals, not the rubber.
BDiggity is offline
Old 03-09-2011 | 01:29 PM
Not silley 241 if you dont know, The impeller in your pump will be fine in both fresh or sea water dont forget to flush after you use in salt water hope this helps
paul buckner is offline
Old 03-13-2011 | 06:48 PM
Got it. I was confused because some call them SEA water and some call them FRESH water. In short, all the impeller does is move the water to the water pump that in turn moves it through the engine.... Isn't that correct? And as long as after going in the ocean, I flush both drives, there should not be any issues.
