What fuel pump to use >
Old 03-09-2011 | 06:55 PM
Default What fuel pump to use
switching from mechanical to electric because my new block wont accept a mechanical. its 350 vortec sbc with lt4 hotcam, performer rpm intake, compression is like 9.8:1, and using a 650 demon carb. should be between 375 to 400 hp at about 5200 rpm. i was looking at the holley pumps and cant decide between the blue or the red. any input would be appreciated.
87MagnumII is offline
Old 03-09-2011 | 06:59 PM
Default Fixx
neither,,a good cheep pump that will last woud be a mallory,,went through tons of holly pumps in the past and the mallory out lasts them by 100 to 1..
FIXX is offline
Old 03-09-2011 | 07:09 PM
Registered User
87 Magnum, I have 4 of these for sale Aeromotive pumps like now 20 hours time on them $120.00 each plus ride. Bob
Attached Thumbnails What fuel pump to use-dsc01132.jpg   What fuel pump to use-dsc01136.jpg   What fuel pump to use-dsc01135.jpg
EXCESS ENERGY is offline
Old 03-09-2011 | 07:40 PM
Rookie's Avatar
I use Mallory 140's (600HP) they are serviceable and inexpensive to rebuild. You could just run a 110 that is internally regulated to 6-7lbs
Rookie is offline
Old 03-09-2011 | 07:43 PM
ok so what kind of flow and pressure do you guys think i need?
Old 03-09-2011 | 08:59 PM
Rookie's Avatar
Anyone correct me if I'm wrong.
400HP x .55 (BSFC)=220lbs/HR
Gas weighs ~6.2lbs/gal
220 / 6.2 = 35.5 gals/Hr
35.5GPH x 30% (safety factor) = 46.15 GPH
6-7PSI
Also fuel pumps are rated at free flow state. Flow and pressure are indirectly proportional. A 110GPH pump puts out about 90GPH @ 6PSI
Rookie is offline
Old 03-09-2011 | 09:23 PM
cool, thanks for all the input
Old 03-09-2011 | 11:03 PM
I would go with one of those aeromotive ones and a nice good pressure valve !
DareDevil is offline
Old 03-10-2011 | 05:26 AM
Great pumps, no issues and reliable!
motorz is offline
