-   -   Cam size with stock rockers (https://www.offshoreonly.com/forums/general-q/249308-cam-size-stock-rockers.html)
stlliberator 03-13-2011 09:33 PM
I was thinking about putting a new cam in my motor. The question I have is how "big" of a roller cam can I run with stock rocker arms? I have lunati lifters already so that shouldn't be a issue. And I'm running emi thunder manifolds too.
jeffswav 03-13-2011 10:33 PM
I use the Comp Pro Magnum Stainless rockers, Crane golds would also be a good choice. This was one of my first upgrades, I have been running them for about 7 years and show no signs of wear. Get rid of the stamped steel GM rockers, they are not adjustable and a weak link.
picklenjim 03-13-2011 11:32 PM
+1
I always considered roller rockers to be one of the first things on my list of priorities. Just curious, you mention you have Lunati lifters already. Do you already have a roller cam in the motor?
stlliberator 03-13-2011 11:39 PM
Ya it's a retro fit cam
picklenjim 03-14-2011 12:01 AM
Not sure as to what the biggest cam would be that you could run with stock rockers. Normally anyone running a roller cam would also be running roller rockers. The real question is how much cam can your engine handle. All depends on what heads, intake, carb, compression, exhaust you have now. All these parts along with the cam must compliment each other. Too much cam with out the other goodies and you'll just slow down. I do see that you have up graded the exhaust.
stlliberator 03-14-2011 10:38 AM
I have the stock 502 heads the 088 rev port heads. I have a dart high rise intake with a 850 cfm carb and stock compression. Which I think is 8.5 to 1. I run the emi exhaust. I bought the motor the guy had the installed a roller cam already. I wanna run a cam to make good power and still not really turn the motor over 5200, since it's still stock lower and heads.
