Glad to hear you got it going Dennis. So, it was the pump?
Eddie |
Yes it was the pump Eddie . Thank you for your help
Dennis,
did you get your dyno sheets yet? |
No I need to call him
My last dyno sheet is in.
Awesome numbers Dennis! That should be a lot of fun!
That should make the HTM fly, nice job.
Very impressive nice job!!!
Originally Posted by dennis r
(Post 3384809)
What fuel are you going to run with that boost.
That was with 110 I am backing the boost down to 12 and running 93 At 12 lbs it still made 1200
Dennis,
Do you have a sheet w/AFR's? on my 572's ended up with 1140hp, 12# boost. Weren't looking for big hp #'s. Had a hard time bringing AFR's in line. Randy |
No I dont have one I would like to see your dyno sheet
1 Attachment(s)
These aren't my final #'s, (finals are on my shops server). Carbs went back to Pro-Systems for changes. Also the BCFC readings were crazy (problems w/flow meters)
Randy |
Very nice Randy, you coming to Hot Boat this year at Brower Park?
YES!! are you?
Every year I stay the whole week from labor day to hot boat
What Drive system are you planning on running?
I will be testing my B-Max out
(Post 3385351)
I will have to look you up this year
| All times are GMT -5. The time now is 10:58 AM. |
