fuel pumps
Old 03-16-2011 | 03:33 PM
Revelocity's Avatar
Unfortunately that KE upgrade part just mounts on the original housing and uses the Mercury diaphram that fails. Too bad they don't make a complete replacement unit - KE resells the Mercury unit.
Anyone know of a shop for rebuilding/replacing the (Merc/Carter?) diaphram as I've got two in need now and another two by the end of the season no doubt? Thanks.
Revelocity is offline
Revelocity's Avatar
Duplicate post
Old 03-16-2011 | 03:49 PM
i read somewhere that holley makes one also,,,http://www.jegs.com/webapp/wcs/store...pump+diaphramg maybe someone knows which one to buy,,,and which one works for the 525 mech. fuel pump,,, part #12-756 or 12-755
TWIN-SPINS is offline
Old 03-17-2011 | 06:32 AM
Here is another thread on the topic using the KE lower.
http://www.offshoreonly.com/forums/g...mendation.html
1BIGJIM is offline
Old 03-17-2011 | 12:22 PM
If I had a Mark IV this is the pump I would use, it's probably the most reliable pump you can get and will pump 450GPH.
http://www.cpperformance.com/p-13167...arbureted.aspx
ThisIsLivin is offline
