fuel pumps
Old 03-15-2011 | 08:05 AM
Registered User
Default fuel pumps
whats the mechanical pump of choise
itbs is offline
Old 03-15-2011 | 08:23 AM
billeickmann's Avatar
And what is the best for an early (2000) 500 EFI ??
billeickmann is offline
Old 03-15-2011 | 09:51 AM
Clay smith.
fbc25el is offline
Old 03-15-2011 | 09:55 AM
For what motor?
picklenjim is offline
Old 03-15-2011 | 10:45 AM
Registered User
carbed 540s
itbs is offline
Old 03-15-2011 | 11:43 AM
Mark IV engine or Sea Water pump mounted?
1BIGJIM is offline
Old 03-15-2011 | 11:49 AM
Registered User
mark IV dart block
itbs is offline
Old 03-15-2011 | 01:31 PM
How much peak HP you are making will determine how many GPM you will need. You can rig the CV Products FP without a regulator up to 750 HP (green spring) but it is pretty pricey. You can spend less than 1/2 the price of a CV if you are in the 500 HP range. Hardin Marine should have what you need.
BenPerfected is offline
Old 03-15-2011 | 07:48 PM
Revelocity's Avatar
Any recommendations for a more reliable "Sea Water pump mounted" fuel pump to replace the standard HP 500 EFI Merc units. The Mercury design diaphrams have a short service life.
Revelocity is offline
Old 03-15-2011 | 09:02 PM
http://www.cpperformance.com/p-12460...6-engines.aspx
1BIGJIM is offline
