Amsoil SVG Sever Lube Water Tolerance?
[QUOTE=dogturd21;3354088]Both lubes turned milky when water was present AND the oil was highly adgitated, as would occur while the drive was engaged. But the marine lube would keep the water in suspension for days, while the non-marine lube would allow the water to seperate in minutes or hours.
[QUOTE]
Would someone that has the Amsoil SVG Severe Gear Lube put some in a jar with ~10% water and shake it until mixed and then see if the water stays disloved or it settles back out?
[QUOTE]
[QUOTE=Rage;3356756][QUOTE=dogturd21;3354088]Both lubes turned milky when water was present AND the oil was highly adgitated, as would occur while the drive was engaged. But the marine lube would keep the water in suspension for days, while the non-marine lube would allow the water to seperate in minutes or hours.
I have already done this: the water will settle out for the most part in about 1-2 minutes.
Borrow your brides blender.
It does a better job.
Ken
Ken
[QUOTE=dogturd21;3357214][QUOTE=Rage;3356756]
Well that is my answer. Thank you!
