MSD Ignition >
MSD Ignition
MSD Ignition
Old 03-23-2011 | 01:34 PM
If they were junk, i cant see why the majority of high dollar proffesional marine engine builders are using the msd marine stuff on 1000HP blower motors.
There are some important things about using a msd. You need use their "marine" boxes. They are potted in epoxy. Also, vibration kills them. I would not consider hard mounting them to the engine. You want to use rubber isolators. They have a computer board in them. How long would your laptop last if you put it in a paint can shaker?
Another issue. Lots of guys like running their stereo's all day at the beach. They dont like working off of low voltage. Trying to get them firing when you have 10 or 11 volts to them is no good. MSD works very well in my opinion in blower motors. I used to idle for very long periods of time when i kept my boat on the river. Fat carbs, low water temps, and blowers, never once did i foul plugs.
Properly mounted, properly wired, they will last. Not saying they are the best, but I do recall HEI module's being kept in glove boxes back in the day because they burnt up so much. How come those race car guys with the backup msd setups dont just drop in a one wire HEI? Does a HEI offer boost retard, timing adjustments on the fly, programmable launch control, or change the limiter with a simple plug in chip?
I just sent my msd billet distributors back to msd for rebuilds. They were 11 years old. They came back with EVERYTHING new, gear, bearing, shimmed, reluctor wheel, pickup, weights, springs, flame arrestors, and cap and rotor. And they repolished the shafts. Not bad for about 100 bucks each. I couldnt have bought the parts myself for that kind of money.
With that being said, i would not hesitate to use a DUI ignition product. But to say msd is junk and theirs is better, is like a ford vs. chevy debate.
MILD THUNDER is offline
Old 03-23-2011 | 01:59 PM
Wally's Avatar
Were doomed!
Just like anything else out there you will always find people that have had problems with a product and are the first to chime in on why its bad. My first experience with MSD was on my 1979 K5 Blazer w/a 383 stroker. That system never failed me once! i had that truck for almost 10 years and after i set up the springs and installed a capacitor on the box it was bullet proof. Then i went and bought the full marine system for my scarab. Mild motors, nothing fancy and the first box died at the begining of the 2nd season....the second box died midway through the 3rd season. Both were mounted on rubber isolators on the transom right above the transom plates. Would i say they are junk? NOPE cause when they ran, they ran good! The ONLY issue i can complain about with MSD is the distributors always seem to rust on me on the inside. I would usually take the cap off 2-3 times a season and sray it down with WD40 or somthing to keep the rust at bay....and MSD knew all about it in the marine eviornment...just had no solution at that time. I havent used them since cause havent had a chance to but would if the price is right and i needed an ign sytem
-Wally
Wally is offline
Old 03-23-2011 | 02:54 PM
What was the turnaround time on that? I think I have to do the same thing. Pretty sure my magnet pick up went out on my Dist, and when I looked at the Dist itt was full of rust. for $100 I'd rather just send it back, and have it rebuilt.
My timing is locked out (was that way, when I bought the boat) wonder if it will come back that way?
cabin fever is offline
Old 03-23-2011 | 03:00 PM
well here's what I have experianced, ran a top sportsman race car for a few years, ran all their latest stuff...digtal/programable box($800+) for box alone( worked fine, pro billet dist, was trash...went thru 5 pick ups in one season...worked with their techs..extra grounds, no alt, carefull on charging, etc...finally one owned up and said...the $25 pickup( made in china are junk) put a crank trigger on..which I did, cured the issues there..talked to many guys at the track that had old dist that worked for years, me included, than had them rebuilt..only to have the pickups start failing left and right...so what I see is the older units were better, and the new pieces are trash....and by the way mallory unalite uses the same pick ups !! and the other thing in most cases on boats, won't see a bit of performance gain from the small boxes VS a good HEI....
ezstriper is offline
Old 03-23-2011 | 09:50 PM
I have ran a 6al back in the day on my mustang and actually is was a hand me down off a buddies truck so I do have faith in them. Apparently from all the post I have to go with marine ignition which is no problem,but I have read several post of people dogging the marine version of the 6al so I was hesitant. I agree this is one of those subject where some have had no issues and some have, just a gamble I guess.
antknee is offline
Old 03-25-2011 | 10:28 PM
Originally Posted by picklenjim
If you think all these race teams out there are wiring up two of them because they are junk then why are they even using them in the first place when there are other ignitions out there?
Just personal opinion and past experience.
Having worked in NASCAR in the Cup series, thats exactly why there are two systems in the race cars. The damned things aren't reliable enough to just have one. Vibration is no doubt a factor in that application.
I'm sure many boat guys never have issues. I've had enough MSD issues in race cars, race motorcycles, and my boat to never buy another one. But thats just me.
They're very affordable, no doubt. If thats what you can afford, I totally understand, I don't mean to slam anyone for running them.
Nowadays my race team (not NASCAR thankfully) runs MoTeC. Damned expensive, but I've found no equal. The boat will be on it too soon enough, they've just released an 'economy' ECU.
My personal opinion is nothing beats a hall effect crank trigger and hall effect cam sensor with a good ECU and eight individual (LS style) coils - especially at higher rpm. The individual coils only firing one cylinder have a better recovery time between collapsing to create a fat spark. This should also be a good thing in blower motors with the higher combustion pressures.
Different strokes for different folks. Most times it comes down to money spent vs. your threshold for drama, like most things in life. Now that I'm finally an old fart past 40, my drama threshold is quite thin
Rookie17 is offline
