Fuel Lines Fittings >
Fuel Lines Fittings
Fuel Lines Fittings
Old 03-23-2011 | 03:13 PM
Default Fuel Lines Fittings
after reading the post about braided lines not working well in boats....who has good rubber ones and fittings that go to AN etc ? thanks Rob
ezstriper is offline
Old 03-23-2011 | 07:40 PM
didnt say they were not good just that they are not Coast Guard approved and they (like all hoses) have a limited life span. Aeroquip does make approved hose but I dont recall the number. part of the problem with hoses is that the ones you used to run and never had issues with are not good with the ethanol fuels. some of the newer hoses state that they are approved for ethanol so check out the manufacturers specs closely before decideing.
compedgemarine is offline
Old 03-23-2011 | 09:07 PM
On the pressure side it should be ss hard line
lightning jet is offline
Old 03-24-2011 | 10:09 AM
Here's what teague sells,
http://teaguecustommarine.com/store/...th=202_299_677
I am also looking at this,
http://www.hosexpress.com/hose/socke...etlesshose.htm
RT930turbo is offline
Old 03-24-2011 | 11:43 AM
cigboat1's Avatar
Artie , did you find the leak yet ?
Jim
cigboat1 is offline
Old 03-24-2011 | 12:21 PM
Jim
Hey Jim,
I've been front to back top to bottom, soaped and pressurized everything, no dice...
I'm wondering if it was the vents when the bowls were filling. I ran the blowers and then closed the boat back up overnight, and no more smell. Hit the pumps and got some slight odor, but cant find a leak or get any smell on my hand anywhere. I wonder if just having the boat inside with no air movement is allowing me to smell even the slightest bit of fuel in the carbs.
Old 03-25-2011 | 07:53 AM
28Eliminator's Avatar
I have used the Aeroquip socket less hose an AN fittings and they work and look good. They look similair to the ones Teague sells.
http://www.summitracing.com/parts/AER-FCN0820/
28Eliminator is offline
