Priming Engine with Oil
I have a rebult Mark IV 461 CI in my Nova with about 4 hours on it. I used it once early last year and winterized it in early october. I DO NOT want to pull the distributor to prime the engine with oil and was wondering if there was another way. I hate to just pull the plugs and shoot fogging oil in the cylinders and rely on that. Any ideas?
Thanks, Ted |
Originally Posted by gofastwannabe
(Post 3365633)
Thanks, Ted |
So I will not have to worry about bearing damage as long as I dont start it...correct?
(Post 3365649)
Thanks for the help Runnin! If it doesn't snow this weekend I may have to pull the cover off. All my buds are headed to LC to get ready for the fast approaching holiday and I don't want to be left out!!
have a great day! Ted |
(Post 3365662)
I would use fogging oil instead of WD-40 as it lubricates better.
Keep the plugs out while it's cranking, it'll spin faster and less pressure on the bearings, easier on the starter.
I have a 598 going in this year that has not been fired in 3 years. Fogger has been sprayed in it 2 twice a year, no oil in the motor. Should I prime the same way or should I take the dist out and prime it? Engine only has 80hrs on it and dont want to trash the bearings!!:eek:
Brad |
I usually prime by cranking with the coil off as well.
Once my guage is movin(usually less than 30 sec) I reconnect the coil, let the starter cool, and fire it up!!! :drink: |
| All times are GMT -5. The time now is 11:30 PM. |
