Hinge pin removal. Drill?? Any tips welcomed >
Old 04-06-2011 | 10:41 AM
Originally Posted by pitts1313
Guys I appreciate all the suggestions. Turned the stick welder up on high and blew a piece off and scared to do anymore. It must be loctite and corrosion. I barely missed the threads when drilling. I went ahead and took to machine shop before I messed up anything.
Good idea! I couldn't believe you were going to take a welding stick to it, but to each their own. At least you know it will be done right now.
wjb21ndtown is offline
Old 04-06-2011 | 11:09 AM
I used a sawzall with a 12" Milwaukee Torch blade...18~21 TPI Bi-Metal. Use cutting oil and a SLOW speed. The pins are stainless and HARD. Be careful in doing any thing or you will be replacing the Gimbal Ring and Skull (Helmet)....$$$
sprink58 is offline
Old 04-06-2011 | 11:16 AM
Mbam's Avatar
Offshoreonly Advertiser
I know it's too late, but when removing the pins use heat first to break down the Loctite. And don't be shy with the heat, need to get the bell housing pretty warm by the pin.
Mbam is offline
Old 04-06-2011 | 01:42 PM
I figured you guys would watch this thread if I went at it with a stick welder. I'm thinking like mbam said, Need to be aggressive with heat and cool it, heat, cool. They were easy to drill, pins had a centering mark inside them. Sawsall good idea to get the bell off quick. Next time heat!, then if strip welding a nut onto pin. I know there must be a reason they red loctite these pins, but why? Are the senders not enough of a back up to keep the pins from screwing out? Starboard drive unbolt with no issues.
pitts1313 is offline
