Jet change needed? >
Jet change needed?
Jet change needed?
Old 04-07-2011 | 03:10 PM
Default Jet change needed?
I'm switching from Stainless Marine Exhaust Manifolds to Eickert Headers. I'm running a holley hp 950 carb, but other than the exhaust change nothing else has changed. Do I need to worry about changing the jets in my carb this spring or am I fine to leave it as is?
endeavour32 is offline
Old 04-07-2011 | 03:47 PM
I doubt an exhaust would cause you need to rejet.
BenPerfected is offline
Old 04-07-2011 | 04:41 PM
No need to change jetting for that.
Griff is offline
Old 04-07-2011 | 05:36 PM
blue thunder's Avatar
If you were already on the edge of lean I would take a look at it. If you are changing plugs keep the old set and after a run or two compare a couple of the old to the new see how much leaner it went. KEs scavenge pretty good if you have a cam with decent overlap.
blue thunder is offline
Old 04-07-2011 | 08:13 PM
Thanks for the inputs guys. I figured I was safe but I'd rather ask and make sure.
