2V vs 5V stereo amp output leads >
Old 04-12-2011 | 10:38 AM
US1 Fountain's Avatar
Ginger or Mary Ann?
Default 2V vs 5V stereo amp output leads
What will be the difference between having 2V vs 4 or 5V amp output leads? Is it even noticeable?
US1 Fountain is offline
Old 04-12-2011 | 10:44 AM
Default Fixx
you just have to make sure your amp can handle the input voltage your putting in to it..lets say your rca out put on your stereo is 5 volts and your amp input can only handle 2 volts then you would be over powering the amp,,the volume will turn up to fast and the music will be distorted..
You want to match the stereo out put with the amp's input level..
FIXX is offline
Old 04-12-2011 | 02:05 PM
The higher the RCA output voltage the better. The greater the signal coming into the amplifier the more efficient and cooler the amp will run.
jay00f4 is offline
Old 04-12-2011 | 03:39 PM
As stated, the higher the output of the deck, the better. The "gain" knob on an amplifier is not a power adjustment, but rather a sensitivity adjustment. As you turn the gain up, you make the input more sensitive to the low voltage audio coming from the source.
As you turn the gain up, the sensitivy magnifies EVERYTHING, not just the audio, but also any noise in the signal, random RF, etc. You're always best served to have the gain as low as possible. You can achieve this with higher input voltages. If you do some searching, there are actually boxes out there that will take a lower input voltage and amplify its output (look up the Audio Control Matrix).
By using lower gain levels, and higher RCA voltage outputs, you can generally achieve a louder and cleaner sounding system than turning the gain up with lower voltage RCA outputs.
DynojetResearch is offline
Old 04-12-2011 | 04:11 PM
Ginger or Mary Ann?
After the responses and not knowing it was an amp related issue, I then double checked my amps owners manuals. They are capable of 200mV -8V input. (JL Audio). For clarification, a call to the JL tech guy resulted in the exact same comments as above.... More noise possible. Thanks!
Old 04-12-2011 | 04:51 PM
JL makes some nice stuff. I would have said I'm sure they will accept at least 5v just by hearing their name. All of the big names with quality products in the industry make amps that will accept 4V+ these days.
Old 04-13-2011 | 01:31 AM
Get 4V minumum inputs. That way if you have split an RCA with Y adapters, you will still have enough signal to the amps.
Griff is offline
