741 cam specs.
Dose anyone have the specs for a 741 cam.
Part Number: 168741 Grind Number: HR-236/359-2S-12 IG
Engine Identification: Start Yr. End Yr. Make Cyl Description 1996 Up CHEVROLET 8 HR-236/359-2S-12 IG camshaft - Ch. 454-502 V8 96-00 Engine Size Configuration 454-502 C.I. V Valve Setting: Intake - .000 Exhaust - .000 Hot/Cold - HOT Lift: Intake @Cam 359 @Valve 610 All Lifts are based on zero lash and theoretical rocker arm ratios. Exhaust @ Cam 372 @Valve 632 Rocker Arm Ratio 1.70 Cam Timing: TAPPET @ .004 Lift: Opens Closes ADV Duration Intake 38.0 BTDC 80.0 ABDC 298.0 ° Exhaust 86.0 BBDC 40.0 ATDC 306.0 ° Spring Requirements: Part Number 99896 Loads Closed 150 LBS @ 1.900 or 1 29/32 Open 466 LBS @ 1.290 Recommended RPM range with matching components Minimum RPM 2200 Maximum RPM 6000 Valve Float 6600 Cam Timing: TAPPET @.050 Lift: Opens Closes Max Lift Duration Intake 11.0 BTDC 45.0 ABDC 107 236.0 Exhaust 59.0 BBDC 5.0 ATDC 117 244.0 |
Not trying to hijack, but does anyone have the same specs for the 731 cam? Specifically, the open/close events - I already know the .050 duration and lift.
Thanks! |
http://www.cranecams.com/product/car...detail&p=24282
Quoting: Not trying to hijack, but does anyone have the same specs for the 731 cam? Specifically, the open/close events - I already know the .050 duration and lift. Thanks! |
| All times are GMT -5. The time now is 04:53 AM. |
