gill hp 500 exhuast
trying to install a set of hp500 ex on my boat its a 89 330 454 and it is hitting everything,,,lol...its hitting the alt now its the fitting on the bottom of the ex,,,so has anyone had this problem??and how do i fix this ....help...lol
try swapping the manifold from one side to other. so the water fitting is at the rear of the motor. Had the same problem that fix mine. Hope this help!
Fixx
What he said,,the fitting are soppose to face towards the outside front of the block or reverse them to the back..
Get a shorter alternator belt and adjust it inward as much as possible.
thanks a bunch guys i will try this weekend
how abought rotten stringers?the lag bolts have nothing to screw into,,,
Originally Posted by tw50
(Post 3376128)
or pour epoxy into the holes, drill a pilot hole and install the lag bolt |
| All times are GMT -5. The time now is 06:06 PM. |
