hvh carb spacer? >
hvh carb spacer?
hvh carb spacer?
Old 04-14-2011 | 10:13 AM
Default hvh carb spacer?
I put a 2" HVH carb spacer on my 502 omc, just wondering if anyone has Dyned there motor,and seen any h.p numbers with the spacer.
intimidator is offline
Old 04-14-2011 | 12:12 PM
OldSchool's Avatar
On a 582 CI N/A engine, the increase was supposedly 18HP on the dyno. Don't know what/if anything would be seen on a stock 502 engine.
OldSchool is offline
Old 04-14-2011 | 12:20 PM
I put a 1" JOMAR Performance tapered 4 hole spacer on my 522 and it improved the throttle response dramatically. The top end difference was barely noticeable, although 18hp is about 1mph. Definitely worth it though, I'm having so much fun jumping on the gas I will probably break my drive now.
ThisIsLivin is offline
Old 04-14-2011 | 08:08 PM
Yup we picked up 1 hp @5600, Took it off and lost 1 hp put it back on made 1 hp more . That was the 1" spacer on a 582hp 515........
formula 382 sr-1 is offline
Old 04-15-2011 | 08:06 PM
same here got more hp . dyno my 540 try dif. kinds the 4hole made the most hp
bajabob is offline
Old 04-15-2011 | 08:09 PM
I picked up 1 mph on my Checkmate with a 516 cid engine...
It's one of those things you just have to try.. Definitely not a miracle cure for anything but it DID work for me...
Your best bet would be to contact Scott at CFM technologies..... I believe he had a hand in the development of it....
http://www.cfm-tech.com/index.htm
Doug
Boatally Insane is offline
Old 04-15-2011 | 11:40 PM
Read what we found out about it on the dyno..had lean issues pulled the spacer off and help out getting the a/f ratio richer.
http://www.offshoreonly.com/forums/g...-arrestor.html
crapr6 is offline
Old 04-16-2011 | 06:49 AM
i did read your post . has same thing on my motor went with a 1000holly. 850 was to small.and the flame arest i went bigger.
bajabob is offline
