-   -   hp500 oil and filter change (https://www.offshoreonly.com/forums/general-q/251653-hp500-oil-filter-change.html)
floyd7811 04-18-2011 03:44 AM
After doing some searching i am still undecided on what oil to use. Motor is a hp500 carb motor.
I have been using valvoline racing vr1 40wt. I am about to change oil and was looking for suggestions on what to use or should i stick with the vr1.
Also any recomendations on oil filter?
Thanks in advance
bajarick 04-18-2011 05:10 AM
I use merc full syn. and merc filters
never any problems.
pacalim1965@yaho 04-18-2011 10:00 AM
Amsoil with merc racing filter, Royal Purple in outdrive
BDiggity 04-18-2011 11:21 AM
i use the valvoline racing oil & napa racing filters
wjb21ndtown 04-18-2011 11:55 AM
Valvoline makes a good oil. I would stay away from Casteroil and Penzoil, but Valvoline, and Mobil 1 are both good. I hear good things about AMS oil, but I don't run it personally. I was running Mobile 1 20-50 full synthetic, but I can't seem to find it anymore. They make a 10-50 now, which for all practical purposes should be the same for me, but I would rather just run a straight 50. I never boat when it's under 60 degrees anyhow.
I also run Royal Purple in my outdrive.
rlj676 04-18-2011 03:32 PM
Go to Wal Mart and get the 5 qt jugs of Mobil 1 20W 50 racing synthetic or V twin oil for under $25.
Here are the filters that you can use, I like Wix after reading on here and elsewhere:
Fram: PH5, DG5
Purolator: L34631
Purolator Pure One: PL34631, PL36461
AC: PF1218
Motorcraft: FL-12A
Napa: 1060
Wix: 51060
Baldwin: B1428 (top rated)
K&N: HP3002
Amsoil: SDF-24
Hastings: LF279
Fleetguard: LF3679
Mercruiser: 35-802885Q
Mobile 1: M1-302
Kendall: K31
Penzoil: PZ45
Quaker State: QS5
Shell: S63, SH38
Texaco: T38, T38B
Warner: PH1218
STP: S01218
Valvoline: V056
Dean Ferry 04-18-2011 03:42 PM
Fram: PH5, DG5
Purolator: L34631
AC: PF1218
Motorcraft: FL-12A
Napa: 1060
Wix: 51060
K&N: HP3002
Amsoil: SDF-24
Hastings: LF279
Fleetguard: LF3679
Mobile 1: M1-302
Kendall: K31
Penzoil: PZ45
Quaker State: QS5
Shell: S63, SH38
Texaco: T38, T38B
Warner: PH1218
STP: S01218
Valvoline: V056
What about the FRAM HP 4? That's what I use, no problems to date?
Dean
Padraig 04-18-2011 03:53 PM
Royal Purple straight 40 weight.
floyd7811 04-18-2011 04:20 PM
Is everyone runnin synthetic? I have heard not to run syn in hp500, to slick and can cause the roller to slide instead of roll on the cam lobe
wjb21ndtown 04-18-2011 05:44 PM
Fram: PH5, DG5
Purolator: L34631
AC: PF1218
Motorcraft: FL-12A
Napa: 1060
Wix: 51060
K&N: HP3002
Amsoil: SDF-24
Hastings: LF279
Fleetguard: LF3679
Mobile 1: M1-302
Kendall: K31
Penzoil: PZ45
Quaker State: QS5
Shell: S63, SH38
Texaco: T38, T38B
Warner: PH1218
STP: S01218
Valvoline: V056
Have you purchased oil yet this year? I went to buy it and can't find 20-50w Mobile 1 anywhere, and Pepboys told me that they stopped making it in favor of 10-50w.
Now I'm scratching my head... I may go with Valvoline full synthetic 20-50 or a straight 50 if I can find it... Maybe Walmart has some old stock left around of the 20-50w M1???
rlj676 05-17-2011 04:31 PM
Sorry, the cheap stuff at Wal Mart is 15w-50, and they no longer carry it.:angry-smiley-038:
The 20W-50 from M1 is the V-twin stuff, which is supposed to be even better (more zinc). That's still out there but it's more expensive.
