Gas questions
1. Why is ethanol bad for boats?
2. If a gas station has ethanol in their gas do they have to put a sticker on the pump saying "may contain upto 10% ethanol" 3. When someone says this motor needs premium will there be a difference between 91 and 93 becasue I have seen both as being labeled premium. |
Fixx
Originally Posted by drpete3
(Post 3386086)
(Post 3386086)
same goes with reg in my region. All comes in 87,, add 10% Eth you now have 89. |
(Post 3386086)
2. If a gas station has ethanol in their gas do they have to put a sticker on the pump saying "may contain upto 10% ethanol" 3. When someone says this motor needs premium will there be a difference between 91 and 93 becasue I have seen both as being labeled premium. 1. Ethanol can start separating from the gas after only 30days. It then sits at the bottom of the tank where the fuel pick up usually is located. 2. Ethanol will attract any moisture that may be in the fuel tank 3. When starting a boat after 30 days or so, you can get a straight shot of ethanol, therefore causing a lean condition and possible detonation to cylinders. Ethanol, obviously alcohol, can also strip the cylinder walls of any oil film, i.e. lean condition. |
Originally Posted by mreedy
(Post 3386152)
The booze will bump up the octane level, 91 would be base prem,, while 93 is 91 + 10% eth.
(Post 3387445)
ahh I didnt know this. So what about the sinage at the pumps. Does it have to tell you if there is ethanol in the fuel?
What about the gas sold at airports? some has lead? How much is it there since there is no road tax?
(Post 3387445)
This one will show state requirements for posting at pumps: http://www.fuel-testers.com/state_gu...anol_laws.html |
smcser, didnt notice you had fuel testes site up there.. LOL
(Post 3387546)
http://pure-gas.org |
| All times are GMT -5. The time now is 07:48 PM. |
