best oil for 525sc? >
best oil for 525sc?
best oil for 525sc?
Old 04-27-2011 | 12:29 PM
Originally Posted by MILD THUNDER
For as little oil as they hold, I would change it more often, than what they recommend. These blowers have a tendency to fill the oil reservoirs with gas, when the seals start to go. Changing it frequently, assures you to catch any fuel in there before any damage to the blowers. I quart of gear lube will cover both blowers.
I used a little pump that hooks to a cordless drill. Sucks it out, and put fresh in. There is a front and rear crankcase on these blowers.
Me, I'd change it every 10-15 hours. Some may say overkill, but for under 10 bucks, and 15 minutes of time, worth it. Those little blowers work hard.
Thanks for the advice. Its my first blower motor and would rather be safe than sorry. What weight gear lube do I use?
Drock78 is offline
Old 04-27-2011 | 02:28 PM
Originally Posted by Drock78
Supercharger was just gone through about 10hrs ago. How many hours should that be changed at?
I changed mine every 25-30hrs. The blower had 500hrs on it and had never been apart.
Griff is offline
Old 06-21-2011 | 09:52 PM
dykstra's Avatar
Whatever weight gear lube you use in your drive. I use 75W90.
dykstra is offline
Old 06-22-2011 | 03:22 PM
Default V-Twin
I picked up off of here a couple of years ago that Mobil 1 V-Twin oil had the best overall performance numbers. Being as this oils is designed to operate in the harshest conditions (air cooled HD) it makes sense to me. Ive run several changes of this and am pleased. My take on the blower fluid is that it IS important to keep an eye on it. I think that some are a little over paranoid and change to often. Doesn't hurt to change often but if your like me, I already have a maintenance list for my toys a mile long. My recommendation is to check the fluid level often as having fluid and not gas is the key. I leave mine in for 50 hours. BTW I LOVE these motors. I just GPS my 27 fever at 78 this weekend with one 525SC with 500 hours pushing it. Little more prop work and I will get it to 80.
Kid Cumberland is offline
