Trouble aligning engine (350 sbc) >
Old 04-30-2011 | 11:06 AM
What purpose does the spring washer serve? Would a lockwasher suffice? What does the spacer do?
cash68 is offline
Old 04-30-2011 | 11:30 AM
There's also a "newer" style rear mount that uses a knurled insert, and is somewhat different. Another possible issue is that if the old monts are shot, they will sag a long ways - to the point where new ones have to be pressed in before the engine will align properly. Sorry - can open, worms everywhere!
Has this engine been aligned with these nounts, etc... since the last time it was taken out? a little more info on the specdifics of what was done or not done since the last time it was aligned would be helpful in shedding light on the potential issues.
wtfo is offline
Old 05-02-2011 | 10:44 AM
I don't really know. Engine was installed by PO. Stern drive not installed. I have an engine alingment tool right now, and I can only get it in about 1" or so, because the flare on the alingmnet tool hits the inside of the gimbal area. It goes through the gimbal bearing just fine, but there is a small flange inside of that, toward the engine. It hits there.
cash68 is offline
Old 05-02-2011 | 10:57 AM
obnoxus's Avatar
Charter Member #1171
can you see/feel the back mount?
between the bellhousing and transom plate will be the fiber washer,,,, wont be able to see the sprging as its inside,,,, but if aligning the bearing doesnt help id go there next
I want to live in a world where a chicken can cross the road and not have its motives questioned.
obnoxus is offline
Old 05-02-2011 | 11:58 AM
Originally Posted by 1BIGJIM
On the rear did you get the springs and fiber washer correct, if you did not, you will never get it to line up moving the front up or down.
Here is a link that shows the lock washer, its #8
http://www.mercruiserparts.com/Show_...ND+SHIFT+CABLE
1BIGJIM is offline
Old 05-02-2011 | 01:30 PM
How precise is the alignment? Will one or two turns of the front mounts in the wrong direction cause a bearing failure? I am pretty sure I'm close, I just don't know if it's "perfect".
cash68 is offline
Old 05-02-2011 | 01:56 PM
If it's not close enough to get the alignment tool in, it's WAY off... you can smoke the coupler and or trash the bearing and seal in the drive upper... Sorry. I'm betting the po didn't put the rear mounts back together correctly... or that they're worn out and sagging.
is the alignment tool hitting the coupler high or low? Put grease on the end of it, push it in as far as you can, and then slide it out carefully and look at where the grease is disturbed...
wtfo is offline
Old 05-02-2011 | 03:07 PM
When its perfect it will slide in easy and bottom out.
You will know when its perfect.
You will never get the drive on if its not.
1BIGJIM is offline
Old 05-02-2011 | 03:44 PM
No, the tool definitely goes in. About 1" or so.
That's just it. The alignment tool is hitting the top and bottom, and left and right. I think it is really close! Again, the tool I am borrowing is hitting the inside gimbal mount plate. The diameter of the last, largest section of the tool does not clear the inner gimbal mount area. It goes through the bearing, perfectly, but there is a lip on the inside gimbal area that is about 1mm smaller in diameter, and the largest area of the tool cannot pass that. It bottoms out on it.
cash68 is offline
Old 05-20-2011 | 07:04 AM
hp500efi's Avatar
Member #9
cash, hope you get this resolved because I need my alignment tool back ASAP . Hoping you can return it before June 1st.
Member of the Liquid Jungle
hp500efi is offline
